The Avid Connector API is the framework for integration of your custom service into the Avid Platform. It was designed from the ground up for a multi-zone environment with deployment across geographically remote machines where multiple service instances are possible. All service discovery and request routing is managed by the Avid Connectivity Service bus, the communication backbone of the Avid Platform. The same API is used internally by MediaCentral Services.
The Connector API is used for clients and services and provides a very simple API to communicate via the bus. Services can also mark operations as Upstream exposed. These operations will automatically become available on Upstream.
